docs:blox:connect-ws2812
3.1 Connecting BLOX to WS2812 Addressable RGB LEDs
OpenBuilds BLOX supports external LED strings, matrixes and rings containing WS2812 based addressable LEDs
  • Max Current: 2A
  • LED Type: WS2812B
Configuration
grblHAL / CONTROL
Make sure to set $536=0-255 (WS2812B LED strip length) in grblHAL settings (CONTROL > Grbl Settings Tab > Scroll down to$536 WS2812B LED strip length > Set the value to 2+'number of LEDs on the attached strip/matrix/circle' and Save That is because BLOX has two onboard LEDs. So if you add a 24-LED strip, you should set $536 = 2+24 thus $536=26
docs/blox/connect-ws2812.1722882368.txt.gz · Last modified: 2024/08/05 18:26 by admin
