docs:blox:connect-ws2812
3.1 Connecting BLOX to WS2812 Addressable RGB LEDs
OpenBuilds BLOX supports external LED strings, matrixes and rings containing WS2812 based addressable LEDs
  • Max Current: 2A
  • LED Type: WS2812B
Configuration
grblHAL / CONTROL
Make sure to set $536=0-255 (WS2812B LED strip length) in grblHAL settings (CONTROL > Grbl Settings Tab > Scroll down to$536 WS2812B LED strip length > Set the value to 2+'number of LEDs on the attached strip/matrix/circle' and Save That is because BLOX has two onboard LEDs. So if you add a 24-LED strip, you should set $536 = 2+24 thus $536=26
To change the LED colors, use the M150 command: “M150 S0 [strip=0] I0 [index 0-Length of LED strip] P255 [brightness 0-255] R255 [red 0-255] U255 [green 0-255] B255 [blue 0-255]
docs/blox/connect-ws2812.1722882307.txt.gz · Last modified: 2024/08/05 18:25 by admin
