Table of Contents
2.7 Switched Output
  • Max Current: 2A
2.7.1 Wiring
BLOX Terminal Device
GND Low side Switched leg
V+ 12-30V (Connected to input power supply positive)
Switched Output Example: Motors / LEDs Switched Output Example: Relays Switched Output Example: IoT Relay / Solenoid
docs/blox/connect-switched-outputs.1723476398.txt.gz · Last modified: 2024/08/12 15:26 by admin
