2.7 Switched Output
  • Max Current: 2A
2.7.1 Wiring
BLOX Terminal Device
GND Low side Switched leg
V+ 12-30V (Connected to input power supply positive)
Switched Output Example: Motors / LEDs Switched Output Example: Relays Switched Output Example: IoT Relay / Solenoid
2.7.2 Configuration
2.7.2.1 grblHAL/CONTROL
No additional grblHAL settings required
Use the M7/M8/M9 commands to control the outputs (Mist/Coolant)
2.7.2.2 LogiBLOX
Use for ON/OFF control of devices attached to the Switched Outputs
Set a PWM value (Useful for dimming LED strips, or controlling the speed of a motor attached to the Switched Outputs)
docs/blox/connect-switched-outputs.1723139396.txt.gz · Last modified: 2024/08/08 17:49 by admin
