2.7 Switched Output
  • Max Current: 2A
2.7.1 Wiring
Switched Output Example: Motors / LEDs Switched Output Example: Relays Switched Output Example: IoT Relay / Solenoid
2.7.2 Configuration
2.7.2.1 grblHAL/CONTROL
No additional grblHAL settings required
Use the M7/M8/M9 commands to control the outputs (Mist/Coolant)
docs/blox/connect-switched-outputs.1722949878.txt.gz · Last modified: 2024/08/06 13:11 by admin
