3.10 Switched Output
  • Max Current: 2A
Switched Output Example: Motors / LEDs Switched Output Example: Relays Switched Output Example: IoT Relay / Solenoid
docs/blox/connect-switched-outputs.1722878736.txt.gz · Last modified: 2024/08/05 17:25 by admin
