3.9 Switched Output
  • Max Current: 2A
Switched Output Example: Motors/LEDs Switched Output Example: Relays Switched Output Example: IoT/Solenoid
docs/blox/connect-switched-outputs.1722878151.txt.gz · Last modified: 2024/08/05 17:15 by admin
