3.9 Switched Output
3.9.1 Electrical Specifications
  • Max Current: 2A
3.9.2 Purpose
Switched Output Example Switched Output Example Switched Output Example
docs/blox/connect-switched-outputs.1722865641.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
