3.9 Switched Output
3.9.1 Electrical Specifications
  • Max Current: 3A
  • Voltage: 24v (Same as Input voltage)
Switched Output Example Switched Output Example Switched Output Example
docs/blox/connect-switched-outputs.1722865474.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
