OpenBuilds BLOX provides support for 2x Bipolar Stepper Motors, with software-controlled current setting and fault monitoring.
  • Motor Max Current: 3.2A
  • Motor Voltage: 3V ideally, higher will limit acceleration
  • Motor Inductance: 1-2mH ideally, higher will limit max speed
2.5.1 Wiring
BLOX Terminal Device
A+ Coil 1 (Red)
A- Coil 1 (Blue)
B- Coil 2 (Green)
B+ Coil 2 (Yellow)
2.5.2 Stepper Driver FAULT modes
Faults that trigger FAULT MODE:
  • Overcurrent (Adjust current down a little)
  • Overtemperature (Adjust current down a little, improve cooling)
  • Turn off power
  • Resolve the issue
  • Turn power back on
2.5.3 Configuration
2.5.3.1 grblHAL/CONTROL
  • $140=xx X-Axis Motor Current (Set appropriate current for stepper motors in use)
  • $141=xx Y-Axis Motor Current (Set appropriate current for stepper motors in use)
  • $4=0 ;Step direction invert = disabled (Required)
  • $1=255 Step idle delay = set to always enabled (Recommended, keeps motors locked to maintain position)
2.5.3.2 BLOX
You can use the Stepper Motors as linear axes. Current, and all motion parameters like calibration and speed profiles are configurable. Supports relative and absolute movements.
You can also use the Stepper Motors as Rotational axes. Current, and all motion parameters like calibration and speed profiles are configurable. Supports relative and absolute movements.
The Stepper Drivers actively monitor for FAULT conditions. FAULT mode for both drivers can be accessed as Digital Sensors
docs/blox/connect-stepper-motors.1723228717.txt.gz · Last modified: 2024/08/09 18:38 by admin
