OpenBuilds BLOX provides support for 2x Bipolar Stepper Motors, with software-controlled current setting and fault monitoring.
  • Motor Max Current: 3.2A
  • Motor Voltage: 3V ideally, higher will limit acceleration
  • Motor Inductance: 1-2mH ideally, higher will limit max speed
2.5.1 Wiring
BLOX Terminal Device
A+ Coil 1
A- Coil 1
B- Coil 2
B+ Coil 2
2.5.2 Configuration
2.5.2.1 grblHAL/CONTROL
  • $140=xx X-Axis Motor Current (Set appropriate current for stepper motors in use)
  • $141=xx Y-Axis Motor Current (Set appropriate current for stepper motors in use)
  • $4=0 ;Step direction invert = disabled (Required)
  • $1=255 Step idle delay = set to always enabled (Recommended, keeps motors locked to maintain position)
docs/blox/connect-stepper-motors.1722951707.txt.gz · Last modified: 2024/08/06 13:41 by admin
