OpenBuilds BLOX provides support for 2x Bipolar Stepper Motors, with software-controlled current setting and fault monitoring.
  • Motor Max Current: 3.2A
  • Motor Voltage: 3V ideally, higher will limit acceleration
  • Motor Inductance: 1-2mH ideally, higher will limit max speed
2.5.1 Wiring
BLOX Terminal Device
A+ Coil 1 (Red)
A- Coil 1 (Blue)
B- Coil 2 (Green)
B+ Coil 2 (Yellow)
2.5.2 Stepper Driver FAULT modes
Faults that trigger FAULT MODE:
  • Overcurrent (Adjust current down a little)
  • Overtemperature (Adjust current down a little, improve cooling)
  • Turn off power
  • Resolve the issue
  • Turn power back on
docs/blox/connect-stepper-motors.txt · Last modified: 2024/08/15 12:52 by admin
