docs:blox:connect-rc-servo
2.4 Connecting BLOX to RC Servo
OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, or other imaginative uses
2.4.1 Wiring
BLOX Terminal Device
GND GND
5V 5V IN
SIG Servo Signal
2.4.2 Configuration
2.4.2.1 grblHAL / CONTROL
For most standard RC Servos that have moves 180 degrees set
  • $33=50 Spindle PWM frequency
  • $34=2 Spindle off Value
  • $35=2 Spindle min value
  • $36=15 Spindle max value
2.4.2.2 BLOX
You can set the Servo Position
docs/blox/connect-rc-servo.1723228779.txt.gz · Last modified: 2024/08/09 18:39 by admin
