docs:blox:connect-rc-servo
3.4 Connecting BLOX to RC Servo
Wiring
OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, or other imaginative uses
Configuration
grblHAL / CONTROL
Make sure to set grblHAL settings (CONTROL > Grbl Settings Tab
$33 Spindle PWM Frequency > Set the value to '50' and for most standard RC Servos that have moves 180 degrees set
  • $33=50
  • $34=2
  • $35=2
  • $36=15
$34/35/36 sets up the timing - resulting in a 0.4 - 3ms pulse witdh range that suits most standard servos You may decrease $34 and $35 to output a shorter pulse than 1ms at min, and increase $36 to get a longer pulse than 2ms at max.
docs/blox/connect-rc-servo.1722883732.txt.gz · Last modified: 2024/08/05 18:48 by admin
