docs:blox:connect-rc-servo
3.6 Connecting BLOX to RC Servo
Wiring
OpenBuilds BLOX provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, or other imaginative uses
Configuration
grblHAL / CONTROL
TIP: Set $33=50 (PWM frequency), $34=5, $35=5 and $36=10 to generate a “standard” PWM signal: 20ms repetition rate, 1 - 2ms pulse length range. You may decrease $34 and $35 to output a shorter pulse than 1ms at min, and increase $36 to get a longer pulse than 2ms at max.
For most standard RC Servos that have moves 180 degrees when $34 and $35 are set to 2 and $36 to 15 - resulting in a 0.4 - 3ms pulse witdh range.
docs/blox/connect-rc-servo.1722864304.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
