2.6 Connecting BLOX to Switches
2.6.1 Switch Wiring
BLOX Terminal Device
GND GND
V+ Power Input (Optional, for powered sensors, filtering or LEDs)
SIG NO/NC terminal of switch
2.6.2 Switch Voltage
5V Endstops (Default)
docs/blox/connect-limit-switches.1723476383.txt.gz · Last modified: 2024/08/12 15:26 by admin
