2.6 Connecting BLOX to Switches
2.6.1 Switch Wiring
2.6.2 Switch Voltage
5V Endstops (Default)
2.6.3 Configuration
2.6.3.1 grblHAL/CONTROL
  • $5=mask Invert limit pins, boolean/mask
  • X=1, and Y=2, so to invert both X and Y (Normally Open Switches) set $5=3
  • X=1, and Y=2, so to NC switches on both X and Y (Both as Normally Open switches) set $5=0
docs/blox/connect-limit-switches.1722949668.txt.gz · Last modified: 2024/08/06 13:07 by admin
