3.6 Connecting BLOX to Switches
TIP: Set the Limit Switch voltage as required: Set Limit Switch Voltage Jumpers
5V Endstops (Default)
docs/blox/connect-limit-switches.1722946224.txt.gz · Last modified: 2024/08/06 12:10 by admin
