3.6 Connecting BLOX to Switches
TIP: Set the Limit Switch voltage as required: Set Limit Switch Voltage Jumpers
penBuilds BLOX can provide power to your limit switches / panel switches / sensors / etc : Please use the jumpers to configure the voltage your endstops need: 5v (the default) would be suitable for most mechanical and optical switches. 24v would be great for inductive sensors. Check your endstops' datasheets to determine which voltage would suit them better.
5V Endstops (Default)
docs/blox/connect-limit-switches.1722946200.txt.gz · Last modified: 2024/08/06 12:10 by admin
