docs:blox:buttons
3.1 Onboard Buttons
Blox has two onboard buttons to control its operation
Button Function
Reset Restarts the device
Mode Can be used to place the device into Bootloader mode, and also available inside the firmware as an accessible input button
3.3.1 Configuration
3.3.1.1 grblHAL/CONTROL
  • Reset reboots the device
  • Mode Button is not assigned
  • Holding MODE while pressing Reset enters Bootloader Mode
3.3.1.2 LogiBLOX
  • Reset Button reboots the device
  • Mode Button is available as a Digital Sensor
In LogiBLOX, the SD Card can be used
To log sensor values to a CSV file
To store Audio files to play using an I2S DAC
Formatting an SD Card on demand (For example whenever the Mode button is pressed in this example)
docs/blox/buttons.1723138863.txt.gz · Last modified: 2024/08/08 17:41 by admin
