docs:blox:blox-wifi-setup
6.6.1 Using WIFI in BLOX firmware
BLOX can connect to 2.4Ghz Wifi Networks
  • Wi-Fi Standards: 802.11 b/g/n
  • Frequency Band: 2.4 GHz
  • Security: WPA/WPA2
  • Max Data Rate: Up to 150 Mbps (802.11n)
6.6.1.1 Wifi Initialization
Use the “Setup Wifi” block to intialize a connection to your Wifi Network. Make sure to use your correct SSID (Network name) and PSK (Password). You can use DHCP, or static IP addresses.
Using DHCP (Dynamic IP) Using Static IP address
6.6.1.2 mDNS Hostname
docs/blox/blox-wifi-setup.1724761972.txt.gz · Last modified: 2024/08/27 12:32 by admin
