docs:blox:blox-wifi-messages
BLOX devices communicate using UDP to send (broadcast) and receive messages. Each message includes a sensor value (analog or digital) and a unique ID Tag you get to set. The tags allows devices to filter whether they need to pay attention to the message
ID Tag-Based Processing:
  • Sending: When BLOX1 sends a message, you tags the sensor value with a specific ID Tag.
  • Receiving: All devices on the network receive the message. However, each BLOX device is configured to act only on messages with specific ID Tags.
    • BLOX2 Example: If BLOX 2 is set up with an IF block to look for a message with a certain ID Tag, it will execute subsequent blocks when a message with that ID Tag is received, using the included sensor value.
    • BLOX3 Example: If BLOX 3 is not set up to listen for that ID Tag, it will ignore the message.
Multiple Listeners:
Multiple BLOX devices can be configured to respond to the same ID Tag, allowing for coordinated actions across devices.
Cross-Platform Compatibility:
Technical Details:
6.6.3.2 Sending Messages
You can send analog or digital sensor values
Note the matching ID Tags (compared to receiving section below) to identify the outgoing messages
Sending an analog sensor valueSending a digital sensor value
6.6.3.3 Receiving Messages
Received messages are available as “sensors” for use on the other device / devices
Note the matching ID Tags (compared to sending section above) to identify the incoming messages
Receiving analog sensor valueReceiving digital sensor value
6.6.3.4 Monitoring messages
Messages are broadcast unencrypted for simplicity. This also allows you to very easily monitor and troubleshoot issues, as well as integrate it into other scripts and programs
For example you can listen out for messages from a computer to help you troubleshoot
You can also see broadcast messages in the BLOX Serial/USB logs
6.6.3.4 3rd party integration
You can use your own code to send and receive UDP messages in the formag of idtag=value on port 49160
For example: Sending via a custom nodejs program
const dgram = require('dgram');
// Create a UDP socket
const client = dgram.createSocket('udp4');
// Enable broadcast on the socket
client.on('listening', function() {
  client.setBroadcast(true);
// The message to send
const message = Buffer.from('analog_read_1_blox_2=115');
// The target port and broadcast address
const PORT = 49160;
const BROADCAST_ADDR = '255.255.255.255';
// Send the message
client.send(message, 0, message.length, PORT, BROADCAST_ADDR, (err) => {
  if (err) {
    console.error(`Error sending message: ${err}`);
  } else {
    console.log('Message broadcasted successfully');
  client.close();
For example: Receiving via a custom nodejs program
// Create a UDP socket for the server
const server = dgram.createSocket('udp4');
// Define the port to listen on
const PORT = 49160;
// Event listener for when the server receives a message
server.on('message', (msg, rinfo) => {
  const message = msg.toString();
  const keyValue = message.split('=');
  // Check if the message is in the expected format
  if (keyValue.length === 2 && keyValue[0] === 'analog_read_1_blox_2') {
    const value = keyValue[1];
    console.log(`Received analog_read_1_blox_2 value: ${value}`);
// Event listener for when the server starts listening
server.on('listening', () => {
  const address = server.address();
  console.log(`Server listening on ${address.address}:${address.port}`);
// Bind the server to the port
server.bind(PORT);
docs/blox/blox-wifi-messages.1724865456.txt.gz · Last modified: 2024/08/28 17:17 by admin
