docs:blox:blox-wifi-messages
BLOX UDP Communication System Overview
Message Sending and Receiving:
BLOX devices communicate using UDP to send (broadcast) and receive messages. Each message includes a sensor value (analog or digital) and a unique TagID you get to set
TagID-Based Processing:
  • Sending: When BLOX1 sends a message, you tags the sensor value with a specific TagID.
  • Receiving: All devices on the network receive the message. However, each BLOX device is configured to act only on messages with specific TagIDs.
    • BLOX2 Example: If BLOX 2 is set up with an IF block to look for a message with a certain TagID, it will execute subsequent blocks when a message with that TagID is received, using the included sensor value.
    • BLOX3 Example: If BLOX 3 is not set up to listen for that TagID, it will ignore the message.
Multiple Listeners:
Multiple BLOX devices can be configured to respond to the same TagID, allowing for coordinated actions across devices.
Cross-Platform Compatibility:
6.6.3.1 Sending Messages
6.6.3.2 Receiving Messages
docs/blox/blox-wifi-messages.1724852758.txt.gz · Last modified: 2024/08/28 13:45 by admin
