docs:software:openbuilds-cam [2025/05/08 14:02] admin |
docs:software:openbuilds-cam [2025/05/08 14:04] (current) admin |
| Line 8: | Line 8: | ||
| ==== 3. Select the controller | ==== 3. Select the controller | ||
| - | Select the relevant Machine and Add-On Tools | + | Select the relevant Machine and Add-On Tools you have, then click on Save |
| - | If you require further customization (normally not needed, so proceed with caution) click on //Show Advanced Settings// | + | Optional: |
