docs:software:lightburn [2024/06/24 12:58] admin |
docs:software:lightburn [2024/08/05 15:15] (current) |
| Line 41: | Line 41: | ||
| - | ==== 2.8.1 Unable to connect | + | == 2.8.1 Unable to connect == |
| Firstly, install the Drivers: https:// | Firstly, install the Drivers: https:// | ||
| Line 47: | Line 47: | ||
| If it still fails to connect, go to Edit Device Settings: | If it still fails to connect, go to Edit Device Settings: | ||
| - | Make sure your Baud Rate is 115200, and you can try with and without DTR Signal (let us know which worked | + | Make sure your Baud Rate is 115200, and you can try with and without DTR Signal (Enabled seems to work best for the BlackBox X32) |
| - | ==== 2.8.2 Laser power is not correct, laser is weak, laser is always on ==== | + | == 2.8.2 Laser power is not correct, laser is weak, laser is always on == |
| Make sure you have S-value Max set to the correct value (Same as what you Set $30 in Grbl Settings) | Make sure you have S-value Max set to the correct value (Same as what you Set $30 in Grbl Settings) | ||
