docs:software:lightburn [2020/06/11 15:17] admin |
docs:software:lightburn [2024/08/05 15:15] (current) |
| Line 7: | Line 7: | ||
| ==== 2. Create a Device ==== | ==== 2. Create a Device ==== | ||
| === 2.1 Select " | === 2.1 Select " | ||
| === 2.2 Select Serial/USB === | === 2.2 Select Serial/USB === | ||
| === 2.3 Give your device a Name and configure the working area sizes === | === 2.3 Give your device a Name and configure the working area sizes === | ||
| === 2.4 Configure the Origin position to your own preference, we recommend front-left === | === 2.4 Configure the Origin position to your own preference, we recommend front-left === | ||
| === 2.5 Click Finish === | === 2.5 Click Finish === | ||
| + | === 2.6 Select the correct PORT === | ||
| + | === 2.7 You are now CONNECTED === | ||
| + | === 2.8 Troubleshooting === | ||
| + | == 2.8.1 Unable to connect == | ||
| + | Firstly, install the Drivers: https:// | ||
| + | If it still fails to connect, go to Edit Device Settings: | ||
| + | Make sure your Baud Rate is 115200, and you can try with and without DTR Signal (Enabled seems to work best for the BlackBox X32) | ||
| + | == 2.8.2 Laser power is not correct, laser is weak, laser is always on == | ||
| + | Make sure you have S-value Max set to the correct value (Same as what you Set $30 in Grbl Settings) | ||
| + | same value as $30 in Grbl Settings | ||
| + | Also make sure Laser Mode is Enabled | ||
| + | Save and Reset when Prompted | ||
