docs:scribe:mount-acro [2024/12/03 19:31] admin |
docs:scribe:mount-acro [2024/12/03 19:32] (current) admin |
| Line 2: | Line 2: | ||
| Using the two included tee nuts and screws install ACRO Pen lifter with the servo flush to the bottom of the ACRO main plate. | Using the two included tee nuts and screws install ACRO Pen lifter with the servo flush to the bottom of the ACRO main plate. | ||
| - | If you have the laser mounting plate installed, please remove it first | ||
| Slide the servo up flush to touch the bottom edge of the main plate | Slide the servo up flush to touch the bottom edge of the main plate | ||
| + | > TIP: If you have the laser mounting plate installed, please remove it first | ||
| - | NOTE: The tee nut flange should face into the main plate slot, as shown above | + | NOTE: The tee nut flange should face into the main plate slot, as shown below |
| No need to over tighten the screws, just snug in place | No need to over tighten the screws, just snug in place | ||
