| Next revision | Previous revision | ||
docs:scribe:mount-acro [2024/12/03 18:31] admin created |
docs:scribe:mount-acro [2024/12/03 19:32] (current) admin |
| Line 1: | Line 1: | ||
| ===== Install Scribe on an OpenBuilds ACRO ===== | ===== Install Scribe on an OpenBuilds ACRO ===== | ||
| - | ==== 1. Download | + | Using the two included tee nuts and screws |
| - | Download OpenBuilds® CONTROL from [[https://software.openbuilds.com|https://software.openbuilds.com]] | + | Slide the servo up flush to touch the bottom edge of the main plate |
| + | > TIP: If you have the laser mounting plate installed, please remove it first | ||
| + | NOTE: The tee nut flange should face into the main plate slot, as shown below | ||
| + | No need to over tighten the screws, just snug in place | ||
