| Next revision | Previous revision | ||
docs:interface:wifi-setup-nextgen [2024/04/23 19:04] admin created |
docs:interface:wifi-setup-nextgen [2024/12/31 16:49] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== OpenBuilds Interface: | + | ===== OpenBuilds Interface: Initial Setup: WIFI and Supporting Files ===== |
| - | Connecting | + | In order to fully utilize |
| + | This wizard will | ||
| + | * Copy the PROBE MACROs to the USB Drive | ||
| + | * Copy the Machine Profiles to the USB Drive | ||
| + | * Copy the Wifi Details | ||
| + | Interface will need these specific files present for proper functioning | ||
| + | ==== 1. Insert the USB drive into your computer ==== | ||
| + | Insert the USB drive you want to use with Interface into your computer | ||
| + | > TIP: Repeat these steps for any other flashdrives | ||
| + | ==== 2. Download and install OpenBuilds CONTROL ==== | ||
| + | Download and install | ||
| + | [[https:// | ||
| + | ==== 3. Run the Wizard from OpenBuilds CONTROL ==== | ||
| + | Start OpenBuilds CONTROL, and launch | ||
| + | ==== 4. Copy the supporting files and Configure Wifi details ==== | ||
| + | Inside the Wizard, select the correct Controller from the list, Configure your Wifi Details (optional if you do not want to use Wifi but highly recommended) and select the USB drive to copy to. | ||
| + | Then click "Copy supporting files to Flashdrive" | ||
| + | ==== 5. The log will show when the copying process has been completed ==== | ||
| + | ==== 6. Safely Remove the Flashdrive ==== | ||
| + | Eject / Safely Remove the Flashdrive | ||
| + | [[{}docs: | ||
