docs:interface:usage-instructions [2021/01/12 13:07] admin |
docs:interface:usage-instructions [2024/08/05 15:15] (current) |
| Line 7: | Line 7: | ||
| > Before you can use it to run a job for the first time, make sure you have | > Before you can use it to run a job for the first time, make sure you have | ||
| - | * [[docs: | + | * [[docs: |
| * Connected your Interface to [[docs: | * Connected your Interface to [[docs: | ||
| * Updated your [[docs: | * Updated your [[docs: | ||
