docs:interface:sidebar
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
docs:interface:sidebar [2022/11/17 14:29]
admin
docs:interface:sidebar [2025/01/16 20:00] (current)
admin
Line 1: Line 1:
 +~~NOCACHE~~
 +  * {{fa>home|Home}}  [[:start|OpenBuilds® Documentation]]
 +      * {{:docs:interface:interface-icon.png?24}}  [[:docs:interface:start|OpenBuilds Interface]]
 +        * 1. {{fa>street-view|Tour}} [[:docs:interface:layout|OpenBuilds Interface - Product Tour]]
 +        * 2. Connect your Interface
 +          * 2.1.1  [[:docs:blackbox:blackbox-icon.png?id=docs:interface:sidebar&media=docs:blackbox:blackbox-icon.png|{{:docs:blackbox:blackbox-icon.png?nolink&24}}]] [[:docs:interface:prepare-blackbox|Prepare your BlackBox]]
 +            * [[:docs:interface:prepare-blackbox-v2.3-2.6|Prepare BlackBox 4X v2.3 - v2.7]]
 +          * 2.1.2 [[:docs:blackbox:blackbox-icon.png?id=docs:interface:sidebar&media=docs:blackbox:blackbox-icon.png|{{:docs:blackbox:blackbox-icon.png?nolink&24}}]] Connect Interface to BlackBox
 +            * {{:docs:blackbox-4x:blackbox-icon.png?24}} [[:docs:interface:connect-blackbox-4x|Connect Interface to BlackBox 4X]]
 +            * {{:docs:blackbox-4x:blackbox-icon.png?24}}[[:docs:interface:connect-blackbox-x32|Connect Interface to BlackBox X32]]
 +        * 3. {{fa>tools|Setup}} Initial Setup
 +          * 3.1 {{fa>microchip|Firmware}}  [[:docs:interface:firmware-update|Firmware Update]]
 +            * Method 1: [[:docs:interface:firmware-update-control|Update via CONTROL]]
 +            * Method 2: [[:docs:interface:firmware-update-wifi|Update via the Internet/Wifi]]
 +            * Method 3: [[:docs:interface:firmware-update-flashdrive|Update via USB Flashdrive]]
 +          * 3.2 {{fa>wifi|Wifi}} [[:docs:interface:wifi-setup-nextgen|Prepare USB Flash drive and Setup Wifi]]
 +        * 4. {{fa>book|Instructions}} Usage Instructions:
 +          * 4.1 {{fa>play|Run a Job}} [[:docs:interface:usage-instructions|Run a Job]]
 +          * 4.2 {{fa>cube|Probe}} [[:docs:interface:usage-probe|Probing]]
 +          * 4.3 {{fa>cogs|Setup}} [[:docs:interface:interface-config|Configuration]]
 +          * 4.4 {{fa>wifi|Wifi}} [[:docs:interface:wifi-upload|Upload Gcode over Wifi]]
 +        * 5. {{fa>question|FAQ}} Frequently Asked Questions
 +          * 5.1 [[:docs:interface:fat32format|Format Flashdrive as FAT32]]
 +          * 5.2 {{:docs:interface:grbl-icon.png?24}}[[:docs:interface:connect-generic|Connect to other Grbl controllers]]
 +          * 5.3 [[:docs:interface:firmware-error-partitions|Firmware Flashing Error: Not enough space / Flash too Small]]
 +          * 5.4 [[:docs:interface:flash-run-jumper|Run/Flash Jumper]]
 +          * 5.5 [[:docs:interface:device-test-mode|Device Test Mode]]
 +          * 5.6 [[:docs:interface:retrofit-x32|Retrofit older Interfaces for X32]]
 +        * 6. Tips and Tricks
 +          * 6.1 [[:docs:interface:blackbox-stack|Stacking your Interface onto your BlackBox]]
-~~NOCACHE~~
-  * {{fa>home|Home}} [[::start|OpenBuilds® Documentation]]
-    * {{:docs:interface:interface-icon.png?24|}}  [[docs:interface:start|OpenBuilds Interface]]
-      * 1. {{fa>street-view|Tour}}  [[docs:interface:layout|OpenBuilds Interface - Product Tour]]
-        * 2.1.1 {{:docs:blackbox:blackbox-icon.png?24|}}  [[docs:interface:prepare-blackbox|Prepare your BlackBox]]
-          * [[docs:interface:prepare-blackbox-v2.7|Prepare BlackBox 4X v2.7]]
-          * [[docs:interface:prepare-blackbox-v2.3-2.6|Prepare BlackBox 4X v2.3 - v2.6]]
-        * 2.1.2 {{:docs:blackbox:blackbox-icon.png?24|}} Connect Interface to BlackBox
-          * {{:docs:blackbox:blackbox-icon.png?24|}}  [[docs:interface:connect-blackbox-4x|Connect Interface to BlackBox 4X]]
-          * {{:docs:blackbox:blackbox-icon.png?24|}}  [[docs:interface:connect-blackbox-x32|Connect Interface to BlackBox X32]]
-      * 3. {{fa>tools|Setup}}  Initial Setup
-        * 3.1 {{fa>wifi|Wifi}}  [[docs:interface:wifi-setup|Wifi Setup]]
-        * 3.2 {{fa>microchip|Firmware}}  [[docs:interface:firmware-update|Firmware Update]]
-          * Method 1:  [[docs:interface:firmware-update-wifi|Update via the Internet/Wifi]]
-          * Method 2:  [[docs:interface:firmware-update-flashdrive|Update via USB Flashdrive]]
-          * Method 3:  [[docs:interface:firmware-update-control|Update via CONTROL]]
-        * 3.3 {{fa>usb|USB}}  [[docs:interface:prepare-usb-drive|Prepare USB Flash drive]]
-      * 4. {{fa>book|Instructions}} Usage Instructions:
-        * 4.1 {{fa>play|Run a Job}}  [[docs:interface:usage-instructions|Run a Job]]
-        * 4.2 {{fa>cube|Probe}}  [[docs:interface:usage-probe|Probing]]
-        * 4.3 {{fa>cogs|Setup}}  [[docs:interface:interface-config|Configuration]]
-      * 5. {{fa>question|FAQ}} Frequently Asked Questions
-        * 5.1 [[docs:interface:fat32format|Format Flashdrive as FAT32]]
-        * 5.2 {{:docs:interface:grbl-icon.png?24|}}  [[docs:interface:connect-generic|Connect to other Grbl controllers]]
-        * 5.3 [[docs:interface:firmware-error-partitions|Firmware Flashing Error: Not enough space / Flash too Small]]
-        * 5.4 [[docs:interface:flash-run-jumper|Run/Flash Jumper]]
-        * 5.5 [[docs:interface:device-test-mode|Device Test Mode]]
-      * 6. Tips and Tricks
-        * 6.1 [[docs:interface:blackbox-stack|Stacking your Interface onto your BlackBox]]
docs/interface/sidebar.1668695379.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
