docs:blox:wifi [2024/08/08 19:19] admin |
docs:blox:wifi [2024/08/15 12:53] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== 3.4 WIFI ===== | + | ====== 3.4 WIFI ====== |
| Blox has onboard Wireless Networking | Blox has onboard Wireless Networking | ||
| Line 7: | Line 7: | ||
| * Security: WPA/WPA2 | * Security: WPA/WPA2 | ||
| * Max Data Rate: Up to 150 Mbps (802.11n) | * Max Data Rate: Up to 150 Mbps (802.11n) | ||
| - | ==== 3.3.3 Configuration ==== | ||
| - | === 3.3.3.1 grblHAL/ | ||
| - | Can be used with CONTROL https:// | ||
| - | Make sure to set grblHAL settings (CONTROL > Grbl Settings Tab) | ||
| - | * **$74=Your Network SSID** | ||
| - | * **$75=Your Network PSK (Password)** | ||
| - | === 3.3.3.2 LogiBLOX === | ||
| - | You can configure your BLOX to join a Wifi Network | ||
| - | You can check if you are connected, and manage the flow of your program accordingly | ||
| - | Supports mDNS Hostnames | ||
| - | Send / Receive UDP Broadcast packets to manage remote sensors and events | ||
| - | Using the Wifi network, you can syncronise local time on the device using NTP, and with valid Time, you can run Scheduled tasks at certain days/times | ||
| - | With an I2S Audio DAC, you can also use the Wifi network to stream audio files, or even do Text-to-speak using the Google TTS API | ||
