docs:blox:sdcard [2024/08/09 18:37] admin |
docs:blox:sdcard [2024/08/15 12:53] (current) admin |
| Line 1: | Line 1: | ||
| - | + | ====== 3.2 SD Card ====== | |
| - | ===== 3.2 SD Card ===== | + | |
| Blox has an onboard SD Card socket. | Blox has an onboard SD Card socket. | ||
| - | ==== 3.3.2 Configuration ==== | ||
| - | === 3.3.2.1 grblHAL/ | ||
| - | * For use with grblHAL' | ||
| - | === 3.3.2.2 BLOX === | ||
| - | * Reset Button reboots the device | ||
| - | * Mode Button is available as a Digital Sensor | ||
| - | * Holding MODE while pressing Reset enters Bootloader Mode | ||
| - | __In BLOX, the SD Card can be used:__ | ||
| - | To log sensor values to a CSV file | ||
| - | To store Audio files to play using an I2S DAC | ||
| - | Formatting an SD Card on demand (For example whenever the Mode button is pressed in this example) | ||
