docs:blox:layout [2024/07/16 18:55] admin |
docs:blox:layout [2024/08/15 12:50] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== Introduction to the OpenBuilds BLOX Features ===== | + | ====== Introduction to the OpenBuilds BLOX Features |
| Line 7: | Line 7: | ||
| * b) **System Buttons**: | * b) **System Buttons**: | ||
| * Reset: Reboots the Interface | * Reset: Reboots the Interface | ||
| - | * Mode: Can be used to put the Interface | + | * Mode: Can be used to put the BLOX into Bootloader mode for firmware updates via the USB-C Port, and also accessible as a user input button for custom |
| * c) **SD Card**: Used for Data Logging and File Storage for access from your custom firmware | * c) **SD Card**: Used for Data Logging and File Storage for access from your custom firmware | ||
| * d) **UART**: 3.3v Serial Port | * d) **UART**: 3.3v Serial Port | ||
| Line 22: | Line 22: | ||
