docs:blox:layout [2024/07/16 18:49] admin |
docs:blox:layout [2024/08/15 12:50] (current) admin |
| Line 1: | Line 1: | ||
| - | ===== Introduction to the OpenBuilds BLOX Features ===== | + | ====== Introduction to the OpenBuilds BLOX Features |
| Line 5: | Line 5: | ||
| * a) **USB-C Socket**: | * a) **USB-C Socket**: | ||
| + | * b) **System Buttons**: | ||
| + | * Reset: Reboots the Interface | ||
| + | * Mode: Can be used to put the BLOX into Bootloader mode for firmware updates via the USB-C Port, and also accessible as a user input button for custom firmware | ||
| + | * c) **SD Card**: Used for Data Logging and File Storage for access from your custom firmware | ||
| + | * d) **UART**: 3.3v Serial Port | ||
| + | * e) **Switched Outputs**: MOSFET switched Outputs, 12-30v (Same as input voltage), Max 2A. Can be used with PWM or On/Off control. | ||
| + | * f) 2x **Switch / Limits Inputs**: Used for connected limit switches for homing, or can also be used as filtered inputs for panel switches or external devices like relay based sensors | ||
| + | * g) 2x **Stepper Motors Outputs**: Used for connecting Stepper motors | ||
| + | * h) **Servo Port**: Used for connecting RC Servos | ||
| + | * i) **Power Input**: | ||
| + | * j) **Beeper**: Used for notifications and alerts from your firmware | ||
| + | * k) **RGB LED Port**: Used for connecting an WS2812 based RGB LED Strip, Circle and Matrix. | ||
| + | * l) **I2C Bus**: Used for connection of Sensors and Modules | ||
| + | * m) **SPI Bus**: Used for connection of Sensors and Modules | ||
| + | * n) **GPIO Pins**: Used for connection of Sensors and Modules | ||
