docs:blox:jumper-limitswitchvoltage [2024/08/05 17:52] admin |
— (current) | ||
| Line 1: | Line 1: | ||
| - | ===== 2.1.1 Set your Endstop Voltages ===== | ||
| - | OpenBuilds BLOX can provide power to your limit switches / panel switches / sensors / etc : Please use the jumpers to configure the voltage your endstops need: 5v (the default) would be suitable for most mechanical and optical switches. 24v would be great for inductive sensors. Check your endstops' | ||
| - | > These jumpers are located underneath the top cover of the BLOX, remove a screw on one of the sides to remove the top cover | ||
| - | Limit 1's and Limit 2's voltages can each be set to individually as needed: | ||
| - | Set the jumper according to the required voltage for the sensor / limit switches attached: | ||
| - | ==== 5V Endstops (Default) ==== | ||
| - | ==== 12-30V Endstops ==== | ||
