| Next revision | Previous revision | ||
docs:blox:jumper-limitswitchvoltage [2024/08/05 12:23] admin created |
— (current) | ||
| Line 1: | Line 1: | ||
| - | ===== 2.1.1 Set your Endstop Voltages ===== | ||
| - | OpenBuilds BLOX can provide power to your limit switches / panel switches / sensors / etc : Please use the jumpers to configure the voltage your endstops need: 5v (the default) would be suitable for most mechanical and optical switches. 24v would be great for inductive sensors. Check your endstops' | ||
| - | > These jumpers are located underneath the top cover of the BLOX, remove a screw on one of the sides to remove the top cover | ||
| - | === 5V Endstops: Set the "Limit V+" Jumper to the 5V Setting === | ||
| - | === 24V Endstops: Set the "Limit V+" Jumper to the 24V Setting === | ||
