docs:blox:firmware-esphome
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
docs:blox:firmware-esphome [2024/08/15 15:07]
admin
docs:blox:firmware-esphome [2024/08/19 17:39] (current)
admin
Line 1: Line 1:
 +====== 5.4 Using BLOX with Home Assistant and ESPHome ======
-======4.4 Using BLOX with Home Assistant and ESPHome======+OpenBuilds BLOX can be used with [[https://esphome.io/|https://esphome.io/]] and [[https://www.home-assistant.io/|https://www.home-assistant.io/]] as a Home Automation controller
-OpenBuilds BLOX can be used with https://esphome.io/ and https://www.home-assistant.io/ to work as a Home Automation controller+{{:docs:blox:pasted:20240815-151757.png?400}}
-=====4.4.1 Requirements=====+----
 +===== 5.4.1 Requirements =====
   * A working Home Assistant installation with the ESPHome Add-On   * A working Home Assistant installation with the ESPHome Add-On
   * Working knowledge of ESPHome   * Working knowledge of ESPHome
-=====4.4.2 Example YAML=====+----
-Here's a basic example configuration YAML file for a BLOX under ESPHome, that you can use as a baseline configuration to build your own configurations+===== 5.4.2 Example YAML =====
 +Here's a basic example configuration YAML file for a BLOX under ESPHome, that you can use as a baseline configuration to build from
 <code> <code>
 esp32: esp32:
   board: esp32-s3-devkitc-1   board: esp32-s3-devkitc-1
   framework:   framework:
     type: arduino     type: arduino
 # Enable Home Assistant API: Use your own API KEY # Enable Home Assistant API: Use your own API KEY
 api: api:
Line 38: Line 43:
           id: stepper_current_2           id: stepper_current_2
           level: 0.3  # Set Stepper 2's default Current to 30%           level: 0.3  # Set Stepper 2's default Current to 30%
 wifi: wifi:
Line 51: Line 55:
 ota: ota:
-  password: "b99d5b4df91e72f2bff548ca73c57010" # Use your own +  password: "b99d5b4df91e72f2bff548ca73c57010" # Use your own
 logger: # Enable Logs logger: # Enable Logs
 web_server: # Show local web interface web_server: # Show local web interface
-  port: 80    +  port: 80
 spi: spi:
Line 63: Line 67:
   miso_pin: 37   miso_pin: 37
-i2c: +i2c:
   sda: 3   sda: 3
   scl: 4   scl: 4
Line 75: Line 79:
     num_leds: 2 # Update count if you add external LEDs     num_leds: 2 # Update count if you add external LEDs
     name: "RGB LEDs"     name: "RGB LEDs"
 number: number:
Line 152: Line 155:
     acceleration: inf     acceleration: inf
     deceleration: inf     deceleration: inf
 binary_sensor: binary_sensor:
   - platform: gpio   - platform: gpio
-    pin: +    pin:
       number: 39       number: 39
       inverted: true       inverted: true
     name: "Input: Limit: X"     name: "Input: Limit: X"
-    pin: +    pin:
       number: 40       number: 40
     name: "Input: Limit: Y"     name: "Input: Limit: Y"
-    pin: +    pin:
       number: 11       number: 11
     name: "Input: Fault: X"     name: "Input: Fault: X"
-    pin: +    pin:
       number: 15       number: 15
Line 201: Line 203:
     transition_length: 2s     transition_length: 2s
     auto_detach_time: 0.1s     auto_detach_time: 0.1s
 </code> </code>
docs/blox/firmware-esphome.1723734459.txt.gz · Last modified: 2024/08/15 15:07 by admin
