| Both sides previous revision Previous revision | |||
docs:blox:firmware-arduino [2024/08/15 17:17] admin |
docs:blox:firmware-arduino [2024/08/19 17:38] (current) admin |
| Line 1: | Line 1: | ||
| - | ======5.2 Using BLOX with the Arduino IDE ====== | + | ====== 5.2 Using BLOX with the Arduino IDE ====== |
| The Arduino IDE provides a flexible and powerful environment for programming BLOX devices using traditional code-based methods. This guide will help you get started by installing the Arduino IDE, setting up the ESP32 cores, and adding the necessary libraries. | The Arduino IDE provides a flexible and powerful environment for programming BLOX devices using traditional code-based methods. This guide will help you get started by installing the Arduino IDE, setting up the ESP32 cores, and adding the necessary libraries. | ||
| - | =====5.2.1 Requirements===== | + | ---- |
| + | ===== 5.2.1 Requirements ===== | ||
| Before getting started, ensure that you have the following: | Before getting started, ensure that you have the following: | ||
| - | * A computer running Windows, macOS, or Linux. | + | * A computer running Windows, macOS, or Linux. |
| - | * An internet connection to download the necessary software and libraries. | + | * An internet connection to download the necessary software and libraries. |
| - | =====5.2.2 Installing Arduino IDE 2===== | + | ---- |
| + | ===== 5.2.2 Installing Arduino IDE 2 ===== | ||
| **Download Arduino IDE 2**: | **Download Arduino IDE 2**: | ||
| - | Visit https:// | + | Visit [[https:// |
| **Install the IDE**: | **Install the IDE**: | ||
| Line 20: | Line 24: | ||
| Follow the installation instructions provided on the website. Once the installation is complete, launch the Arduino IDE. | Follow the installation instructions provided on the website. Once the installation is complete, launch the Arduino IDE. | ||
| - | =====5.2.3 Installing the ESP32 Cores===== | + | ---- |
| + | ===== 5.2.3 Installing the ESP32 Cores ===== | ||
| **Open the Arduino IDE**: | **Open the Arduino IDE**: | ||
| Line 30: | Line 36: | ||
| In the " | In the " | ||
| - | > https:// | + | > [[https:// |
| Click " | Click " | ||
| Line 41: | Line 46: | ||
| In the search bar, type " | In the search bar, type " | ||
| - | =====5.2.4 Installing the OpenBuilds BLOX Library===== | + | ---- |
| + | ===== 5.2.4 Installing the OpenBuilds BLOX Library ===== | ||
| **Open the Library Manager**: | **Open the Library Manager**: | ||
| Go to `Sketch > Include Library > Manage Libraries`. | Go to `Sketch > Include Library > Manage Libraries`. | ||
| **Search for the BLOX Library**: | **Search for the BLOX Library**: | ||
| Line 54: | Line 60: | ||
| - | Alternatively, | + | Alternatively, |
| - | =====5.2.5 Getting Started with BLOX on Arduino IDE===== | + | ---- |
| + | ===== 5.2.5 Getting Started with BLOX on Arduino IDE ===== | ||
| **Select the ESP32-S3 Board**: | **Select the ESP32-S3 Board**: | ||
| Line 66: | Line 74: | ||
| Connect the BLOX device to your computer via USB. Ensure the correct port is selected in `Tools > Port`. | Connect the BLOX device to your computer via USB. Ensure the correct port is selected in `Tools > Port`. | ||
| - | Also set: | + | Also set: |
| * USB CDC On Boot = Enabled | * USB CDC On Boot = Enabled | ||
| Line 77: | Line 85: | ||
| - | =====5.2.6 Pinmap for custom firmware ===== | + | ---- |
| + | ===== 5.2.6 Pinmap for custom firmware ===== | ||
| If you are not planning on using our library to control the onboard devices as part of your code, you can use the Pin map below to get you started with your own code | If you are not planning on using our library to control the onboard devices as part of your code, you can use the Pin map below to get you started with your own code | ||
| // WS2812 LEDs | // WS2812 LEDs | ||
| #define LED_PIN | #define LED_PIN | ||
| Line 88: | Line 99: | ||
| // Stepper 1 | // Stepper 1 | ||
| - | #define DIR_1 8 | + | #define DIR_1 8 |
| - | #define STEP_1 | + | #define STEP_1 |
| #define ENABLE_1 | #define ENABLE_1 | ||
| #define FAULT_1 | #define FAULT_1 | ||
| Line 97: | Line 108: | ||
| #define DIR_2 12 | #define DIR_2 12 | ||
| #define STEP_2 | #define STEP_2 | ||
| - | #define ENABLE_2 | + | #define ENABLE_2 |
| - | #define FAULT_2 | + | #define FAULT_2 |
| // Remember to setup MCP4725 I2C DAC (Addr 0x61) to set Stepper Driver Current | // Remember to setup MCP4725 I2C DAC (Addr 0x61) to set Stepper Driver Current | ||
| Line 125: | Line 136: | ||
| void setCurrent(float milliAmps) { | void setCurrent(float milliAmps) { | ||
| - | // Calculate reference voltage: Convert milliAmps to mV output from DAC | + | // Calculate reference voltage: Convert milliAmps to mV output from DAC |
| float millivolt = milliAmps / 5.0 / 0.22; | float millivolt = milliAmps / 5.0 / 0.22; | ||
| // Map the millivolt value to the DAC range (0 to 3300 mV to 0 to 4096) | // Map the millivolt value to the DAC range (0 to 3300 mV to 0 to 4096) | ||
| int dacValue = map(millivolt, | int dacValue = map(millivolt, | ||
| // Your own logic here to apply the dacValue to the correct DAC to set the current | // Your own logic here to apply the dacValue to the correct DAC to set the current | ||
