docs:blox:firmware-arduino [2024/08/14 20:44] admin |
docs:blox:firmware-arduino [2024/08/19 17:38] (current) admin |
| Line 1: | Line 1: | ||
| - | ======4.2 Arduino IDE Setup====== | + | ====== |
| The Arduino IDE provides a flexible and powerful environment for programming BLOX devices using traditional code-based methods. This guide will help you get started by installing the Arduino IDE, setting up the ESP32 cores, and adding the necessary libraries. | The Arduino IDE provides a flexible and powerful environment for programming BLOX devices using traditional code-based methods. This guide will help you get started by installing the Arduino IDE, setting up the ESP32 cores, and adding the necessary libraries. | ||
| - | =====4.2.1 Requirements===== | + | ---- |
| + | ===== 5.2.1 Requirements ===== | ||
| Before getting started, ensure that you have the following: | Before getting started, ensure that you have the following: | ||
| - | - A computer running Windows, macOS, or Linux. | + | * A computer running Windows, macOS, or Linux. |
| - | - An internet connection to download the necessary software and libraries. | + | |
| - | =====4.2.2 Installing Arduino IDE 2===== | + | ===== 5.2.2 Installing Arduino IDE 2 ===== |
| **Download Arduino IDE 2**: | **Download Arduino IDE 2**: | ||
| - | Visit https:// | + | Visit [[https:// |
| **Install the IDE**: | **Install the IDE**: | ||
| Line 20: | Line 24: | ||
| Follow the installation instructions provided on the website. Once the installation is complete, launch the Arduino IDE. | Follow the installation instructions provided on the website. Once the installation is complete, launch the Arduino IDE. | ||
| - | =====4.2.3 Installing the ESP32 Cores===== | + | ---- |
| + | ===== 5.2.3 Installing the ESP32 Cores ===== | ||
| **Open the Arduino IDE**: | **Open the Arduino IDE**: | ||
| Line 30: | Line 36: | ||
| In the " | In the " | ||
| - | > https:// | + | > [[https:// |
| Click " | Click " | ||
| Line 41: | Line 46: | ||
| In the search bar, type " | In the search bar, type " | ||
| - | =====4.2.4 Installing the OpenBuilds BLOX Library===== | + | ---- |
| + | ===== 5.2.4 Installing the OpenBuilds BLOX Library ===== | ||
| **Open the Library Manager**: | **Open the Library Manager**: | ||
| Go to `Sketch > Include Library > Manage Libraries`. | Go to `Sketch > Include Library > Manage Libraries`. | ||
| **Search for the BLOX Library**: | **Search for the BLOX Library**: | ||
| Line 54: | Line 60: | ||
| - | Alternatively, | + | Alternatively, |
| - | =====4.2.5 Getting Started with BLOX on Arduino IDE===== | + | ---- |
| - | **Select the ESP32 Board**: | + | ===== 5.2.5 Getting Started with BLOX on Arduino IDE ===== |
| + | **Select the ESP32-S3 Board**: | ||
| Go to `Tools > Board` and select the ESP32-S3 Development board for your BLOX device. | Go to `Tools > Board` and select the ESP32-S3 Development board for your BLOX device. | ||
| Line 66: | Line 74: | ||
| Connect the BLOX device to your computer via USB. Ensure the correct port is selected in `Tools > Port`. | Connect the BLOX device to your computer via USB. Ensure the correct port is selected in `Tools > Port`. | ||
| - | Also set: | + | Also set: |
| * USB CDC On Boot = Enabled | * USB CDC On Boot = Enabled | ||
| Line 73: | Line 81: | ||
| **Upload a Sketch**: | **Upload a Sketch**: | ||
| - | You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly. | + | You can now write or upload a sketch to your BLOX device. Use the examples provided in the BLOX library to get started quickly. |
| + | ===== 5.2.6 Pinmap for custom firmware ===== | ||
| + | If you are not planning on using our library to control the onboard devices as part of your code, you can use the Pin map below to get you started with your own code | ||
| + | // WS2812 LEDs | ||
| + | #define LED_PIN | ||
| + | // RC Servo | ||
| + | #define PIN_SERVO | ||
| + | // Stepper 1 | ||
| + | #define DIR_1 8 | ||
| + | #define STEP_1 | ||
| + | #define ENABLE_1 | ||
| + | #define FAULT_1 | ||
| + | // Remember to setup MCP4725 I2C DAC (Addr 0x60) to set Stepper Driver Current | ||
| + | // Stepper 2 | ||
| + | #define DIR_2 12 | ||
| + | #define STEP_2 | ||
| + | #define ENABLE_2 | ||
| + | #define FAULT_2 | ||
| + | // Remember to setup MCP4725 I2C DAC (Addr 0x61) to set Stepper Driver Current | ||
| + | // Limits Inputs | ||
| + | #define LIMIT_SENSOR_1 | ||
| + | #define LIMIT_SENSOR_2 | ||
| + | // Mosfets | ||
| + | #define PIN_MOSFET1 | ||
| + | #define PIN_MOSFET2 | ||
| + | // Beeper | ||
| + | #define BUZZER_PIN | ||
| + | // I2C | ||
| + | #define I2C_SDA | ||
| + | #define I2C_SCL | ||
| + | // SPI | ||
| + | #define SPI_MOSI | ||
| + | #define SPI_MISO | ||
| + | #define SPI_SCK | ||
| + | // SD Card | ||
| + | #define SD_CS 5 | ||
| + | void setCurrent(float milliAmps) { | ||
| + | // Calculate reference voltage: Convert milliAmps to mV output from DAC | ||
| + | float millivolt = milliAmps / 5.0 / 0.22; | ||
| + | // Map the millivolt value to the DAC range (0 to 3300 mV to 0 to 4096) | ||
| + | int dacValue = map(millivolt, | ||
| + | // Your own logic here to apply the dacValue to the correct DAC to set the current | ||
