docs:blox:fcc [2024/07/31 14:35] admin |
docs:blox:fcc [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| ===== OpenBuilds® BLOX ===== | ===== OpenBuilds® BLOX ===== | ||
| Line 14: | Line 9: | ||
| - | [[: | + | [[https:// |
| ==== Product Manual ==== | ==== Product Manual ==== | ||
| - | ==== FCC Warning | + | ---- |
| + | ==== FCC Information | ||
| This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, | This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, | ||
| Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment. | Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment. | ||
| NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, | NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, | ||
| - | However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, | ||
| - | which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: | + | However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, |
| - | -- Reorient or relocate the receiving antenna. | + | * Reorient or relocate the receiving antenna. |
| + | * Increase the separation between the equipment and receiver. | ||
| + | * Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. | ||
| + | * Consult the dealer or an experienced radio/TV technician for help. | ||
| - | -- Increase the separation between the equipment and receiver. | + | The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction |
| - | -- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. | + | ---- |
| - | -- Consult the dealer or an experienced radio/TV technician for help. | + | |
| - | The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction | + | |
