docs:blox:fcc [2024/07/31 14:33] admin |
docs:blox:fcc [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| - | {{: | + | ===== OpenBuilds® BLOX ===== |
| + | ==== Layout Information ==== | ||
| + | [[https:// | ||
| - | ===== OpenBuilds® BLOX ===== | ||
| - | Terminal Information ( {{ : | + | ==== Product Manual ==== |
| - | This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, | + | ==== FCC Information ==== |
| - | Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment. | ||
| - | NOTE: This equipment has been tested and found to comply | + | This device complies |
| - | However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, | ||
| - | which can be determined | + | Any changes or modifications not expressly approved |
| - | -- Reorient or relocate the receiving antenna. | ||
| - | -- Increase | + | NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment |
| - | -- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. | ||
| - | -- Consult the dealer or an experienced radio/TV technician for help. | + | However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: |
| + | * Reorient or relocate the receiving antenna. | ||
| + | * Increase the separation between the equipment and receiver. | ||
| + | * Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. | ||
| + | * Consult the dealer or an experienced radio/TV technician for help. | ||
| The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction | The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction | ||
