docs:blox:fcc [2024/07/31 14:28] admin |
docs:blox:fcc [2024/08/05 15:15] (current) |
| Line 1: | Line 1: | ||
| + | ===== OpenBuilds® BLOX ===== | ||
| + | ==== Layout Information ==== | ||
| - | This device complies with part 15 of the FCC Rules. Operation is subject | + | ( {{ : |
| - | Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment. | + | [[https:// |
| - | NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, | + | ---- |
| - | However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, | + | ==== Product Manual ==== |
| - | which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: | ||
| - | -- Reorient or relocate the receiving antenna. | + | {{: |
| - | -- Increase the separation between the equipment and receiver. | + | ---- |
| - | -- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. | + | ==== FCC Information ==== |
| - | -- Consult the dealer or an experienced radio/TV technician for help. | + | |
| + | This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, | ||
| + | Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment. | ||
| + | NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, | ||
| + | However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: | ||
| + | * Reorient or relocate the receiving antenna. | ||
| + | * Increase the separation between the equipment and receiver. | ||
| + | * Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. | ||
| + | * Consult the dealer or an experienced radio/TV technician for help. | ||
| The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction | The device has been evaluated to meet general RF exposure requirement. The device can be u sed in portable exposure condition without restriction | ||
