docs:blox:examples-xystage [2024/08/19 17:39] admin |
— (current) | ||
| Line 1: | Line 1: | ||
| - | ====== 7.2 XY Stage Examples ====== | ||
| - | BLOX can be used with 2-axes machines | ||
| - | ===== 7.2.1 Initialization for XY Stages ===== | ||
| - | Before you can use a 2-axis system, you need to set it up so the controller knows how to control it correctly. Make use of the Initialization Blocks to configure them for use with the BLOX: | ||
| - | ^Linear Actuators^Details | ||
| - | | **[[https:// | ||
