docs:blox:examples-switched-output [2024/08/22 13:31] admin |
docs:blox:examples-switched-output [2024/08/22 13:33] (current) admin |
| Line 2: | Line 2: | ||
| BLOX can be used to turn devices on/off or control their speed/ | BLOX can be used to turn devices on/off or control their speed/ | ||
| Line 13: | Line 15: | ||
| ===== 6.4.3.2 Use a switched output to turn a device on/off ===== | ===== 6.4.3.2 Use a switched output to turn a device on/off ===== | ||
| - | For example, an LED strip wired to Switched Output 1, and a PIR motion sensor wired to GPIO1. When the motion sensor detects movement, we turn on the LED strip | + | For example, an LED strip wired to Switched Output 1, and a PIR motion sensor wired to GPIO1. When the motion sensor detects movement, we turn on the LED strip. |
| Line 23: | Line 25: | ||
