docs:blox:examples-switched-output [2024/08/22 13:26] admin |
docs:blox:examples-switched-output [2024/08/22 13:33] (current) admin |
| Line 2: | Line 2: | ||
| BLOX can be used to turn devices on/off or control their speed/ | BLOX can be used to turn devices on/off or control their speed/ | ||
| Line 13: | Line 15: | ||
| ===== 6.4.3.2 Use a switched output to turn a device on/off ===== | ===== 6.4.3.2 Use a switched output to turn a device on/off ===== | ||
| + | For example, an LED strip wired to Switched Output 1, and a PIR motion sensor wired to GPIO1. When the motion sensor detects movement, we turn on the LED strip. | ||
| ===== 6.4.3.3 Use a switched output with PWM ===== | ===== 6.4.3.3 Use a switched output with PWM ===== | ||
| + | For example, an LED strip wired to Switched Output 1, and a PIR motion sensor wired to GPIO1. LED strip is always on, but only at 20% brightness. When the PIR motion sensor detects movement, we increase the brightness to 100% | ||
