docs:blox:examples-display [2024/08/26 17:39] admin |
docs:blox:examples-display [2024/08/27 12:10] (current) admin |
| Line 53: | Line 53: | ||
| BLOX toolbox includes a Display Bitmap File block. | BLOX toolbox includes a Display Bitmap File block. | ||
| Click on UPLOAD IMAGE to upload your images and convert them | Click on UPLOAD IMAGE to upload your images and convert them | ||
| Line 61: | Line 61: | ||
| Click on Open Image to select the file, then play around with the settings sliders to get the desired effect | Click on Open Image to select the file, then play around with the settings sliders to get the desired effect | ||
| + | ==== 6.4.8.7 Monitor Sensor values on the display ==== | ||
| + | BLOX includes two special blocks to monitor analog sensor values in real time on a display. You can use the Guage or Oscilloscope to display a sensor' | ||
| + | ^ Gauge View ^ Oscilloscope View ^ | ||
| - | ==== 6.4.8.7 Monitor Sensor values on the display | + | ==== 6.4.8.8 Printing Text ==== |
| + | You can also print text | ||
