docs:blox:examples-audio-i2s [2024/08/26 13:58] admin |
docs:blox:examples-audio-i2s [2024/08/26 17:20] (current) admin |
| Line 1: | Line 1: | ||
| ====== 6.4.7 Audio: I2S ====== | ====== 6.4.7 Audio: I2S ====== | ||
| - | BLOX can be used to to play audio in more complicated projects via an external I2S Audio decoder module | + | BLOX can be used to to play audio in more complicated projects via an external I2S Audio decoder module. |
| + | I2S (Inter-IC Sound) is a serial bus interface standard used for connecting digital audio devices. It is designed to transmit high-quality audio data between devices, such as digital-to-analog converters (DACs), and microcontrollers. | ||
| Line 7: | Line 9: | ||
| ==== 6.4.7.1 Jumpers on the PCM5102a Module ==== | ==== 6.4.7.1 Jumpers on the PCM5102a Module ==== | ||
| - | ^ H ^ Name ^ Description ^ LOW ^ HIGH ^ | + | Use a soldering iron to close the relevant solder jumpers on your module: |
| - | | H1L | FLT | Filter Select | Normal Latency (SELECT) | Low Latency | | + | |
| - | | H2L | DEMP | De-emphasus control | OFF (SELECT) | ON | | + | |
| - | | H3L | XMST | Soft Mute Control | Muted | Unmuted (SELECT) | | + | |
| - | | H4L | FMT | Audio Format Selection | I2S (SELECT) | Left Justified | | + | |
| - | {{: | + | ^Name^Description^Setting| |
| + | |SCK|Jumper to connect SCK to GND|CLOSED| | ||
| + | ^H^Name^Description^LOW^HIGH^Jumper must be set to| | ||
| + | |H1L|FLT|Filter Select|**Normal Latency** |Low Latency|**L** | | ||
| + | |H2L|DEMP|De-emphasus control|**OFF** |ON|**L** | | ||
| + | |H3L|XMST|Soft Mute Control|Muted|**Unmuted** |**H** | | ||
| + | |H4L|FMT|Audio Format Selection|**I2S** |Left Justified|**L** | | ||
| ==== 6.4.7.2 Wiring PCM5102a Module ==== | ==== 6.4.7.2 Wiring PCM5102a Module ==== | ||
| - | {{: | + | Note: You can use any of the available GPIO pins to connect the module. Just be sure to initialize the firmware with the correct assignments. |
| ==== 6.4.7.3 Initialize PCM5102a Module ==== | ==== 6.4.7.3 Initialize PCM5102a Module ==== | ||
| + | Once Set up, wired and initialized - you can proceed to use the module to play sounds in your firmware | ||
| ===== 6.4.7.4 I2S Audio: Play audio files from SD Card ===== | ===== 6.4.7.4 I2S Audio: Play audio files from SD Card ===== | ||
| + | Place an audio file on the SD Card, and let your firmware play it | ||
| + | This can be used for audible notifications, | ||
| + | Tip: Not shown, but there are Play Next buttons etc as well | ||
| + | You can also play the NEXT/PREV or RANDOM file (useful for jukebox like projects, random noises for halloween props etc) | ||
| ===== 6.4.7.5 I2S Audio: Play audio via stream URL ===== | ===== 6.4.7.5 I2S Audio: Play audio via stream URL ===== | ||
| + | Enable WIFI and let your firmware play a streamable audio link for you. Could make for a nice jukebox/web radio project | ||
| ===== 6.4.7.6 I2S Audio: Use text to speech ===== | ===== 6.4.7.6 I2S Audio: Use text to speech ===== | ||
| + | Enable WIFI, and let your firmware call the Google Text to Speech API to create verbal notifications | ||
| + | ===== 6.4.7.7 I2S Audio: Volume and Tone ===== | ||
| + | BLOX provides the ability to set the volume and tone of the audio as well: | ||
