| Both sides previous revision Previous revision | |||
docs:blox:examples-audio [2024/08/26 14:15] admin |
docs:blox:examples-audio [2024/08/26 14:19] (current) admin |
| Line 7: | Line 7: | ||
| ===== 6.4.6.1 Notifications via onboard beeper ===== | ===== 6.4.6.1 Notifications via onboard beeper ===== | ||
| - | BLOX provides a couple default noises you can use to signify events with an audible notification | + | BLOX provides a couple default noises you can use to signify events with an audible notification |
| {{docs: | {{docs: | ||
| ===== 6.4.6.2 Notifications via onboard beeper, using RTTTL melodies ===== | ===== 6.4.6.2 Notifications via onboard beeper, using RTTTL melodies ===== | ||
| + | BLOX can also play custom melodies provided in RTTTL format | ||
| + | RTTTL stands for Ringing Tone Text Transfer Language, a simple text-based format used to encode monophonic ringtones for mobile phones, particularly for older models before the advent of polyphonic and MP3 ringtones. | ||
| + | It was in use for a very long time, so there are thousands of RTTTL melodies available online: | ||
| + | Find some examples on | ||
| + | * https:// | ||
| + | * https:// | ||
| + | * https:// | ||
| + | Simply paste the RTTTL string into the "Play RTTTL Melody" | ||
