docs:blox:examples-actuator
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
docs:blox:examples-actuator [2024/08/21 17:44]
admin
docs:blox:examples-actuator [2024/08/27 12:28] (current)
admin
Line 9: Line 9:
 ===== 6.4.2.1 Wiring ===== ===== 6.4.2.1 Wiring =====
-See [[docs:blox:connect-stepper-motors|Wiring BLOX: Stepper Motors]]+See [[:docs:blox:connect-stepper-motors|Wiring BLOX: Stepper Motors]]
Line 23: Line 23:
 Use the table below to find some default values to use for Current settings, Steps-per-mm and Acceleration Use the table below to find some default values to use for Current settings, Steps-per-mm and Acceleration
-^Linear Actuators^Details  ^Initialization Blocks| + Linear Actuators   Details  Initialization Blocks
-|  **[[https://openbuildspartstore.com/v-slot-mini-v-linear-actuator-bundle/|V-Slot® Mini V Actuator]]  ** \\ {{:docs:linear-actuators:actuator1.png}}  |Belt Driven \\ GT2-2M Timing Belts \\ 30T Pulley \\ NEMA 17 Motor | **Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-250mm/sec \\ **Recommended Stepper Current:** 1.0A | +|  **[[https://openbuildspartstore.com/v-slot-mini-v-linear-actuator-bundle/|V-Slot® Mini V Actuator]]  ** \\ {{:docs:linear-actuators:actuator1.png}}  |Belt Driven \\ GT2-2M Timing Belts \\ 30T Pulley \\ NEMA 17 Motor|**Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-250mm/sec \\ **Recommended Stepper Current:** 1.0A|
-|  **[[https://openbuildspartstore.com/v-slot-nema-17-linear-actuator-bundle-belt-driven/|V-Slot® NEMA 17 Belt Actuator]]  ** \\ {{:docs:linear-actuators:actuator2.png}}  |Belt Driven \\ GT2-2M Timing Belts \\ 30T Pulley \\ NEMA 17 Motor | **Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-250mm/sec \\ **Recommended Stepper Current:** 1.0A | +|  **[[https://openbuildspartstore.com/v-slot-nema-17-linear-actuator-bundle-belt-driven/|V-Slot® NEMA 17 Belt Actuator]]  ** \\ {{:docs:linear-actuators:actuator2.png}}  |Belt Driven \\ GT2-2M Timing Belts \\ 30T Pulley \\ NEMA 17 Motor|**Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-250mm/sec \\ **Recommended Stepper Current:** 1.0A|
-|  **[[https://openbuildspartstore.com/nema-17-belt-and-pinion-bundle/|Belt and Pinion NEMA 17 Actuator]]  ** \\ {{:docs:linear-actuators:actuator4.png}}  |Belt Driven \\ GT2-2M Timing Belts \\ 30T Pulley \\ NEMA 17 Motor | **Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 1.0A | +|  **[[https://openbuildspartstore.com/nema-17-belt-and-pinion-bundle/|Belt and Pinion NEMA 17 Actuator]]  ** \\ {{:docs:linear-actuators:actuator4.png}}  |Belt Driven \\ GT2-2M Timing Belts \\ 30T Pulley \\ NEMA 17 Motor|**Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 1.0A|
-|  **[[https://openbuildspartstore.com/nema-23-belt-pinion-actuator-bundle/|Belt and Pinion NEMA 23 Actuator]]  ** \\ {{:docs:linear-actuators:actuator5.png}}  |Belt Driven \\ 3GT-2M Timing Belts \\ 20T Pulley \\ NEMA23 Motor | **Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 2.2A | +|  **[[https://openbuildspartstore.com/nema-23-belt-pinion-actuator-bundle/|Belt and Pinion NEMA 23 Actuator]]  ** \\ {{:docs:linear-actuators:actuator5.png}}  |Belt Driven \\ 3GT-2M Timing Belts \\ 20T Pulley \\ NEMA23 Motor|**Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 2.2A|
-|  **[[https://openbuildspartstore.com/v-slot-nema-23-linear-actuator-belt-driven/|V-Slot® NEMA 23 Belt Actuator]]  ** \\ {{:docs:linear-actuators:actuator3.png}}  |Belt Driven \\ 3GT-2M Timing Belts \\ 20T Pulley \\ NEMA23 Motor | **Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 1.5A | +|  **[[https://openbuildspartstore.com/v-slot-nema-23-linear-actuator-belt-driven/|V-Slot® NEMA 23 Belt Actuator]]  ** \\ {{:docs:linear-actuators:actuator3.png}}  |Belt Driven \\ 3GT-2M Timing Belts \\ 20T Pulley \\ NEMA23 Motor|**Steps per millimeter:** 53.33 \\ **Recommended Acceleration:** +-900mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 1.5A|
-|  **[[https://openbuildspartstore.com/v-slot-nema-17-linear-actuator-bundle-lead-screw/|V-Slot® NEMA 17 Lead Screw Actuator]]  ** \\ {{:docs:linear-actuators:actuator6.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 17 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-300mm/sec² \\ **Recommended Feedrate:** 0-100mm/sec \\ **Recommended Stepper Current:** 1.2A | +|  **[[https://openbuildspartstore.com/v-slot-nema-17-linear-actuator-bundle-lead-screw/|V-Slot® NEMA 17 Lead Screw Actuator]]  ** \\ {{:docs:linear-actuators:actuator6.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 17 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-300mm/sec² \\ **Recommended Feedrate:** 0-100mm/sec \\ **Recommended Stepper Current:** 1.2A|
-|  **[[https://openbuildspartstore.com/v-slot-nema-23-linear-actuator-bundle-lead-screw/|V-Slot® NEMA 23 Lead Screw Actuator]]  ** \\ {{:docs:linear-actuators:actuator7.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.5A | +|  **[[https://openbuildspartstore.com/v-slot-nema-23-linear-actuator-bundle-lead-screw/|V-Slot® NEMA 23 Lead Screw Actuator]]  ** \\ {{:docs:linear-actuators:actuator7.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.5A|
-|  **[[https://openbuildspartstore.com/c-beam-linear-actuator-bundle/|C-Beam Actuator]]  ** \\ {{:docs:linear-actuators:actuator8.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-800mm/sec \\ **Recommended Stepper Current:** 1.7A | +|  **[[https://openbuildspartstore.com/c-beam-linear-actuator-bundle/|C-Beam Actuator]]  ** \\ {{:docs:linear-actuators:actuator8.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-800mm/sec \\ **Recommended Stepper Current:** 1.7A|
-|  **[[https://openbuildspartstore.com/c-beam-xlarge-linear-actuator-bundle/|C-Beam XLarge Actuator]]  ** \\ {{:docs:linear-actuators:actuator9.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.7A | +|  **[[https://openbuildspartstore.com/c-beam-xlarge-linear-actuator-bundle/|C-Beam XLarge Actuator]]  ** \\ {{:docs:linear-actuators:actuator9.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.7A|
-|  **[[https://openbuildspartstore.com/c-beam-double-wide-gantry-actuator-bundle/|C-Beam Double Wide Actuator]]  ** \\ {{:docs:linear-actuators:actuator10.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.7A | +|  **[[https://openbuildspartstore.com/c-beam-double-wide-gantry-actuator-bundle/|C-Beam Double Wide Actuator]]  ** \\ {{:docs:linear-actuators:actuator10.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.7A|
-|  **[[https://openbuildspartstore.com/c-beam-tension-xl-linear-actuator-bundle/|C-Beam Tension XLarge Actuator]]  ** \\ {{:docs:linear-actuators:actuator12.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/second \\ **Recommended Stepper Current:** 1.7A |+|  **[[https://openbuildspartstore.com/c-beam-tension-xl-linear-actuator-bundle/|C-Beam Tension XLarge Actuator]]  ** \\ {{:docs:linear-actuators:actuator12.png}}  |Lead Screw Driven \\ TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/second \\ **Recommended Stepper Current:** 1.7A|
Line 50: Line 50:
-^2 Axis Actuators^Details^Initialization Blocks| + 2 Axis Actuators   Details   Initialization Blocks
-|  **[[https://openbuildspartstore.com/c-beam-xlarge-x-y-table-bundle/|C-Beam XLarge X/Y Table]]  **{{:docs:linear-actuators:actuator11.png?100}}  |Lead Screw Driven\\ TR8*8-2P (4 starts) Leadscrew\\ NEMA 23 Motor | **Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.7A | +|  **[[https://openbuildspartstore.com/c-beam-xlarge-x-y-table-bundle/|C-Beam XLarge X/Y Table]]  **{{:docs:linear-actuators:actuator11.png?100}}  |Lead Screw Driven  TR8*8-2P (4 starts) Leadscrew \\ NEMA 23 Motor|**Steps per millimeter:** 400 \\ **Recommended Acceleration:** +-500mm/sec² \\ **Recommended Feedrate:** 0-80mm/sec \\ **Recommended Stepper Current:** 1.7A|
-|  **[[https://openbuildspartstore.com/acro/|OpenBuilds ACRO System]]  ** \\ {{:docs:blox:pasted:20240819-124444.png?100}}  |Belt Driven \\ GT2-2M Timing Belts \\ 14T Pulley \\ NEMA 17 Motor | **Steps per millimeter:** 114.29 \\ **Recommended Acceleration:** +-1200mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 1.2A |+|  **[[https://openbuildspartstore.com/acro/|OpenBuilds ACRO System]]  ** \\ {{:docs:blox:pasted:20240819-124444.png?100}}  |Belt Driven \\ GT2-2M Timing Belts \\ 14T Pulley \\ NEMA 17 Motor|**Steps per millimeter:** 114.29 \\ **Recommended Acceleration:** +-1200mm/sec² \\ **Recommended Feedrate:** 0-500mm/sec \\ **Recommended Stepper Current:** 1.2A|
 ===== 6.4.2.4 Homing ===== ===== 6.4.2.4 Homing =====
 Its beneficial to add the "Home Stepper Motor" block to the initialization as well, that way later moves can make use of absolute positioning Its beneficial to add the "Home Stepper Motor" block to the initialization as well, that way later moves can make use of absolute positioning
Line 63: Line 62:
 > TIP: Remember to install a Limit switch at the minimum (Zero-end) of travel > TIP: Remember to install a Limit switch at the minimum (Zero-end) of travel
-During initialization, the controller will move the motors until it hits the homing switch. Then it will perform a pull off and finally set its internal coordinates to ZERO.  You can then perform absolute moves relative to this zero point. +During initialization, the controller will move the motors until it hits the homing switch. Then it will perform a pull off and finally set its internal coordinates to ZERO. You can then perform absolute moves relative to this zero point.
-^ Single Axis Homing ^ 2-Axes Homing ^ + Single Axis Homing   2-Axes Homing  |
-| {{:docs:blox:pasted:20240821-171322.png}} | {{:docs:blox:pasted:20240821-171732.png}} |+|{{:docs:blox:pasted:20240821-171322.png}}|{{:docs:blox:pasted:20240821-171732.png}}|
Line 72: Line 71:
 ===== 6.4.2.5 Moving ===== ===== 6.4.2.5 Moving =====
-Use the "Move Stepper Motor" blocks to move the actuator(s).  You can do Relative moves ("Forward" or "Reverse" by some distance from current location) or Absolute moves ("To" a specific position, relative to the Zero point set by homing). If you make use of the "Apply Analog Sensor Value" block and place the "Move Stepper Motor" block inside it, you can map the sensor value to the Motor as well. +Use the "Move Stepper Motor" blocks to move the actuator(s). You can do Relative moves ("Forward" or "Reverse" by some distance from current location) or Absolute moves ("To" a specific position, relative to the Zero point set by homing). If you make use of the "Apply Analog Sensor Value" block and place the "Move Stepper Motor" block inside it, you can map the sensor value to the Motor as well.
-> The "Wait for move to complete" tickbox will force the code to wait for the actuator to reach its commanded position before continuing with the program. That is usually the option you need.  With an analog sensor application you may want to untick it - that way as the sensor changes the value, the position of the actuator can be changed in near realtime to match, rather than waiting for the last move to complete first. +> The "Wait for move to complete" tickbox will force the code to wait for the actuator to reach its commanded position before continuing with the program. That is usually the option you need. With an analog sensor application you may want to untick it - that way as the sensor changes the value, the position of the actuator can be changed in near realtime to match, rather than waiting for the last move to complete first.
-^ Absolute Positioning example ^ Relative positioning Example ^ Position relative to sensor value  + Absolute Positioning example   Relative positioning Example   Position relative to sensor value  |
-| {{:docs:blox:pasted:20240821-172203.png}} | {{:docs:blox:pasted:20240821-172227.png}} | {{:docs:blox:pasted:20240821-172304.png}} |+|{{:docs:blox:pasted:20240821-172203.png}}|{{:docs:blox:pasted:20240821-172227.png}}|{{:docs:blox:pasted:20240821-172304.png}}|
Line 84: Line 83:
 You can also rotate the motor a number of partial and/or full rotations using the "Rotate Stepper Motor" block, in applications where the logic does not apply linearly, for example with a Stepper motor spinning Pan Head on a camera slider or similar You can also rotate the motor a number of partial and/or full rotations using the "Rotate Stepper Motor" block, in applications where the logic does not apply linearly, for example with a Stepper motor spinning Pan Head on a camera slider or similar
 +Initialization:
 +{{:docs:blox:pasted:20240827-122753.png}}
 +Moving a rotational axis:
 {{:docs:blox:pasted:20240821-172734.png}} {{:docs:blox:pasted:20240821-172734.png}}
docs/blox/examples-actuator.1724262264.txt.gz · Last modified: 2024/08/21 17:44 by admin
